Komori 425 BP impression issues
richard crabbe
2011
Lancaster, Ohio
I have a problem with second unit in this older press where I am not obtaining good impression even after packing blanket with same packing as removed. Just purchased this press and feel I got a lemon. Is there any relief out there for me?
Bit more info required...can you describe in more detail?
Presumably you've printed dry solids? Have you backed off pressure till print breaks up? Any prominent low spots that may indicate damage? If so these areas can be 'built up' in severe cases by in situ electro-plating. Have you checked the plate to blanket pressure? There should be a plate on last unit that carries the undercut and standard packings info.
  • 425 bp :0
    Old press indeed. First get rid of any firearms or other implements that can cause a self inflicted mortal injury.
    As I recall this press didn't run on bearers. There should be .1 mm-.004in gap between "non" bearers while on impression. Please check your manual.
    The eye-com system needs constant attention as it is a transmition device rather than reflective.
    2nd unit typically takes the hit in the case of a crash where alot of folded up sheet go in press.
    You may have to pack to print.
    Throne
    Who did his BP time in the mid 90's
    My sympathies go out to all BP pressmen. I can only hope that the dreaded brush dampening system was junked in favour of 3rd party equipment. One saving grace...Mabeg feeder was usually quite reliable but maybe Throne can comment with more authority than I.
    Brush damps omfg! First one I messed with had dhalgrens, second one I ran for 3 years+ and get this, it was called a "Super Sprint" L426BP and it had very first generation Komorimatics. Mabeg feeders on both. Can't recall any real feeder head issues except getting foot and pile height sorted. It was that damn eye-com that kicked my *** the most. Keep it free of dust! I swear we ordered blankets two dozen at a time.
    Throne
    Who is enjoying his LSX529
