KMS connection to PQC-D II
Discussion in 'Komori Printing Presses' started by Vic the Printer, Jul 19, 2018.
Tags:
  1. Vic the Printer
    Vic the Printer Member
    Aug 2008
    70
    United States
    Can KMS connect to an older PQC with a magnetic card reader for ink presetting…
  2. CHOCK
    3,056
    Hi Sir
    Normally when you are Mixing Old Tech Electronic Components TTL -FET vs New Tech Component like SMD-Mosfet ibgt ETC ,most of the time NOT function, to due there are Not compatible, simple becasue the electrical/electronic ,caratheristic of components
    electronics +Software or Firmware are NOT compatible .
    But is matter that you can try.
    Let me know
  3. Vic the Printer
    Aug 2008
    70
    United States
    That IS my question, basically want to find out how I can connect the moxa to the older PQC serial connection
  4. CHOCK
    3,056
    I would like that you contact: http://www.moxa.com/support
    in Order to get the support and the Fact , how you can do it in base to
    the Hardware and Software Support for PQC Komori.
  5. presselectronics
    presselectronics Senior Member
    Oct 2011
    150
    North America
    PQC DII was not made by Komori, but by Toyo Denki. I've seen some creative attempts to download ink key profiles, via the magnetic card reader, but it's a lot of work for very little return. Easier to just upgrade the magnetic card reader to a floppy disc reader, or better yet, buy a new press.
  6. Vic the Printer
    Aug 2008
    70
    United States
    I wish I could afford to buy a new press :) would upgrading to a floppy reader add the interface to connect KMS using moxa?
  7. presselectronics
    Oct 2011
    150
    North America
    Moxa is just a brand name, like Advantech, used on a lot of Komori PCs for serial interfaces. KMS stands for Komori Monitoring System, and even if you could get the floppy interface to work, there would still be no 'monitoring'. The 'newer' presses interface the PQC with the press PLC (computer that runs the press). So without that, the best you could hope for is a PC to store your job ink key profiles. My recommendation is that any PQC older than a III, is just not worth the effort, sorry.
  8. Vic the Printer
    Aug 2008
    70
    United States
    sorry should have included more details.. I have already setup a PC with the PCC software that converts the CIP3 to Inkprofile graph and ultimately convert the graph into text, which represents the key settings for the different units with ink set etc..
    which works perfectly.. and but this is the end of the line so far… one would have to enter this info into the console manually. Now if I could only connect the PC to the Console so that KMS can do it's job.
    As for Moxa… I have also installed moxa in the PC, and have configured for the press…. and since inside the console there are 2 open RS-232C plugs… which I was hoping can be used for serial connection?
  9. sarath425143
    sarath425143 New Member
    May 2021
    India
    did you connect the older pqc with magnetic card derader to pc for ink presetting
  10. Vic the Printer
    Aug 2008
    70
    United States
    Unfortunately I have not yet.. however I know for a fact it's possible to do.
  11. sarath425143
    May 2021
    India
