I have a StahlFolder T1-52 and the screen is stuck on Initialize rC Please Wait OBSERVATIONS ON THE MACHINE 1) DISPLAY SCREEN Initialize rC Please wait. 2) A12, CAN GLOBAL, 5v dc LED1 WAS ON. 3) A12, 24v dc, LED8 WAS ON. 4) GREEN LED's FOR U11 INVERTER DRIVES WERE FLASHING. 5) FUSES(F2, F3, F4) IN A12, B-CPU-10 WERE CHECKED OKAY. 6) FUSE(F1) IN A123, B-EXT-20 WAS CHECKED OKAY. 7) FUSES(F24, and F26) WERE CHECKED OKAY. 8) SM1(F2, F3, and F6) WERE CHECKED OKAY. 9) G12 GREEN LED (DC ok) WAS ON and 24v dc WAS MEASURED. 10) B-VIS-10 BOARD 5v dc LED1 WAS ON. 11) B-VIS-10 BOARD FUSE (F2) WAS CHECKED OKAY I am trying to load the programming for the new Inverter drive but when trying to search, it cannot detect the drive. Please Help
Hi sir: Please do the following steps: 1) Perform a visual inspection : look for loose and broken wires, improperly seated connectors, loose or broken wires misset switch, missing jumpers. and so on. Chech for obviously damaged component(components burned or discolore due to overheating); Dust + dirt + tear +wear 2) Reseating Boards and components: Edge connectors are a common souorce of problems. Power down the system and remove the PC boards. Examine the edge connector for contamination and clean with contacts cleaner contacts. Reseat any loose components 9suc as scoketed ICs) . Reseat the boards and power up. 3) Power supply checks: Check the power supply for missing voltages and voltages out of spec. A digital multimieter DMM can be necessary, as voltage specifications are quite tight: logic supplies for example: must be within + 0.5 percent of 5Vdc. All the multiple supplies and all must be checked. 4) Board swapping: Board swapping involves the substitutiono of a known good board for a suspect one. 5) Clock for CPU: Check the frecuency with frequency counter or a DMM included frecuency counter( like Fluke DMM) Reset CPU: reset cpu see the attached schematic.
Hi, I have checked and rechecked your recommendation and it turns out that FH.1057060/2# B-EXT-20, A123 Board is missing from the Electrical board. i have to reorder since our last Engineer has misplaced it. Will advise if any errors after installing the new FH.1057060/2# B-EXT-20, A123 Board. Kind regards.
