Ideal 7228-90 backgauge toothed belt replacement
Adprint
Does anyone know how to replace this - mine is stripped and needs replacing but I can't figure out how the drive shaft is freed so that the belt can be slipped off the spiral drive shaft plastic belt drive sprocket. Got it off the drive motor side but now stuck as to what to do next.
Good day. I have the same issue. Could you please advise on the parameters of the back support toothed belt for Ideal 7228 (part number 9004 528)?
  • Hi sir;
    need the part belt or other?
    I figured out the issue.
    Part number – 9004 528
    Profile - T5
    Number of teeth – 105
    Length – 525 mm
    Width – 10 mm
    Material - polyurethane.
    My opinion is that the part is standard, you can use any manufacturer.
    Hi Sir, yes is possible, that you have reason.
    Most manufacturer, they doing the same: Like the manufacturers of Fitness machines= Treadmill, and so on.
    Need something Sir More?
    Blessings
    Found the belt, just a standard type belt details as follows..
    T5 - 450 - 10 GAT Gates PU Timing Belt
    Synchro-power T5 Pitch 10 x 450mm 90T
