IDEAL 4810-95EP ERT 04 error
Discussion in 'Cutters and Trimmers' started by deebo, Aug 15, 2018.
  1. deebo
    deebo Member
    Aug 2018
    6
    Austin
    Something to do with the key pad I presume. any ideas. I can't find anything online.
  2. CHOCK
    1,378
    the problem Error 04:
    Please check the function and value of the potentiometer (see diagnostic routine).
    Use the schematic Diagrams.
    Let me know
    Blessing
    superchock@yandex.com
    cell+WhatsApp:+505 8861 1441
  3. deebo
    deebo Member
    Aug 2018
    6
    Austin
    What's the diagnostic routine? I replaced the potentiometer. That worked but now have a new problem. Can get the backgage calibrated. It's about 2 inches off. Can't find a way to calibrate or reset. The thread that says to hold cm and #9 doesn't fix it.
  4. CHOCK
    1,378
    Hi sir;
    Attached is there the diagnostic routine(backgauge recalibration)
    Blessing
  5. deebo
    deebo Member
    Aug 2018
    6
    Austin
    Thanks for the reply. Unfortunately, this is not working either. When i power on holding the cm/inch switch, the screen shows 8888888888 and NOT Test.
  6. deebo
    deebo Member
    Aug 2018
    6
    Austin
    By the way, this is TRIUMPH 4850-95 ep. I feel like when I changed to potentiometer, it had instructions to calibrate, I can't find those instructions anymore, anywhere. Somewhere, someone knows the simple code to fix this. I was having trouble with my screen going dim and flashing off when I jogged paper on the cutter bed, i press multiple buttons on the keybad and then realized the safety switch on the bottom was set off. I reset it and when the cutter powered back up, the measurements were off so I know it has something to do with the key pad.
  7. CHOCK
    1,378
    Hi sir;
    Attached is there the diagnostic routine For EP 4810
    Hope you can fix it.
    Blessing
    Mobile +WhatsApp:+505 8861-1441
  8. deebo
    deebo Member
    Aug 2018
    6
    Austin
    Thank you sir, The key pad checks out, I don't see a way to change the calibration from what you posted. The key pad is about 2 inches off what the actual size is. Normally, when the backgage is all the way back it would read 17.72. Now it reads 20.45, My cutter cant go to 20 inches. There has to be a way to change what the keypad reads vs what the actual cut is.
  9. CHOCK
    1,378
    Hi
    I must remember you that post and definition is NOT mine, is coming from factory.
    If you have difference , you must be replace the keypad, since inside is coming EPROM( software) can be corrupted.
    All the rest of the machine is Electrical components, contactor, limit switch, etc. However you must tight very well any connection and clean it, included from keypad: 1 more thing that you can do it, if you are looking from dry or cold solder joint: Reheating and test again, see if the flat cable is ok or dirty, clean it very well and tight very well.
    Blessing
    Mobile+WhatsApp:+505 8861 1441
