i need help please (clc 3220 c1)
mostafa
2014
canon 3220
i have Canon clc 3220 c1 colour
The Normal print quality but very weak
I opened the machine in the morning and printed the image trembling ؟ I do not know why؟
  • Can you describe more what you mean by "image trembling". Or can you scan a small section that shows the problem and post/attach it so we can see what you are seeing.
    Normal troubleshooting is to determine if the print quality issue affects all colors or one specific color.
    i sorry for delay
    thanks alot for your post jeff
    I used a 3220 for many years and I never had a laser issue. A few times I had toner get under the transfer belt causing one color to be offset from the next and the fix was carefully removing and cleaning the underside (inside) of the transfer belt. Also our 3200/3220 fusers would die by getting distorted and commonly would get a lump about 1,000 prints before dying totally which sometimes caused odd irregularities in the print.
    I created a quick pdf that I used to see how colors were aligning - it's an 11 x 17 sheet with simple lines of C, M, Y, and K so I could see how they align along the print (attached.)
    thank you very much mr.jeff the hazy dont apper again when i turn machine off and on many once (i don't any thing) ... but quality not good i don't why ?
    thank you for your help again ....
