hp indigo 5000 running calibrate bid Engage/Disengage failed
Discussion in 'HP Indigo Digital Presses' started by Sergio Serge, May 12, 2021.
  1. Sergio Serge
    Sergio Serge Senior Member
    Jan 2018
    102
    nj
    my cyan ink contaminate my magenta ink so i am trying to run bid engage /disengage wizard to to calibrated but it give me this error message attached
    1-black ink is not connected to the bid
    2-the bid of the ink is not installed
    3-the bid of the ink is bypassed
    no of the error message is true my machine run all CMYK all the ink are installed but the postion of each ink is
    position 1 yellow
    position 2 empty
    position 3 cyan
    position 4 magenta
    position 5 black
  2. indigo2015
    indigo2015 Member
    Aug 2015
    65
    rome (Italy)
    Did you change ink and bid position in software well?
    Need to go to options/press configuration/inks and bids and change the position.
    After replace the ink file. Go to install ink/ink replacement/select your ink go next next until the end of wizard and select cyan 4.0
