hp indigo 5000 pc and monitor now power
Discussion in 'HP Indigo Digital Presses' started by Sergio Serge, Dec 7, 2022.
  1. Sergio Serge
    Sergio Serge Member
    Jan 2018
    90
    nj
    Hello all , i have a problem no power to the pc and monitor ,the ups work i checked the in and out powered
    but when i check the power in the pc cable and pc monitor no power
    could you help please ?
    i did the fallowing
    checked the cable wires between wall and pc cable is fine
    i checked the power in the connector in the PDU witch control pc and monitor i found 0 volt
  2. White rabbit
    White rabbit Member
    Apr 2013
    71
    USA
    i would bypass the pdu. an extension cord to the wall from the pc and monitor should get u running. if that works, im wondering if there is a fuse involved. not that familiar with 5000
  3. krukov
    krukov Member
    Oct 2019
    74
    IDK
    If all cables are ok, then it's UPS issue. Bypass the UPS, connect cables without UPS.
  4. Sergio Serge
    Sergio Serge Member
    Jan 2018
    90
    nj
    it was the Ru relay not activated we changed and problem was resolved
    thank you so much
