hp indigo 5000 dripping oil in first start
Discussion in 'HP Indigo Digital Presses' started by indigo2015, Mar 6, 2017.
  1. indigo2015
    indigo2015 Member
    Aug 2015
    64
    rome (Italy)
    Hello guys,
    I have an issue with my hp indigo 5000.
    Some times when i go to ready, for the first time in the morning a lot of imaging oil drops everywhere where the blanket is.
    Only does it in the first start, after i dont have the problem in all day, so i dont think its because of a pipe its tap.
    Any suggestion? thanks
  2. Kringle
    Kringle Member
    Oct 2013
    94
    California USA
    Look at the foam gasket on the itm hood where it seals to the suction fan in the side frame. I was having this problem with my 3050 and we noticed the gasket was torn. Problem went away after replaced. Also, do a flow calibration.
  3. FFR428
    FFR428 Senior Member
    Feb 2008
    438
    CT
    What image oil filters are you using? HP tech bulletin switched to a new style filter # B1B32A long life filters for the 5XXX series. These ended all image oil foaming and overflow issues we were having. Old style filters were crap. Also dump and clean both recycled and fresh IO tanks. Fill with fresh IO. We do these every 3-4 ink tank rebuild cycles. After first filter change do new about 300k. We get now like 500K before it starts again. Kringle has good advice too be sure to check everything. Tape from the PIP lead edges can get sucked into the feed hose and clog it causing overflows too. So be careful peeling those off. There's a easy way to do the flow cal but not HP recommended. Probably because it's too easy. :)
  4. Sergio Serge
    Sergio Serge Senior Member
    Jan 2018
    102
    nj
    check the cleaning station oil exit
    check the tube in the back of the machine if its clug
    if every things looks good in you still have the problem bypass the auto color calibration than do the color calibration manual you will be fine
  5. abdoul rhamane
    abdoul rhamane New Member
    Feb 2021
    burkina faso
    Hello I have a problem since yesterday on the hp 5000. Here is a picture of the problem. Help me if possible thank you
  6. Kringle
    Kringle Member
    Oct 2013
    94
    California USA
  7. indigo2015
    indigo2015 Member
    Aug 2015
    64
    rome (Italy)
    Here in the image I think you have bid problem. Probably magenta or cyan. Need to change them.
  8. Sergio Serge
    Jan 2018
    102
    nj
    Cyan bid as you can see there's magenta bend vertical witch mean cyan bid had a problem
