highlights dot gain
AlfredV
Peru
We are printing in a Komori S40, paper type 1 and 2 and some time we have to do big dot gain compensation curve specially in highlights. Example: Starting our calibration process with linear plate 25% become in 44% on paper, 50% in 72 and 75 in 89 aprox.
I really appreciate some advice to help me to understand what is real reason of this excessive dot gain.
Thanks in advance
Paper type 1 and 2? You need to be a little more specific, coated uncoated, matt/gloss etc.
But let's leave that for a minute. Is it only the highlight dot, how about the shadows? Are they filling in ie is an 80% dot going solid?
Press dot gain could be any of the following: poor quality ink, ink/damp out of balance, paper type (uncoated tends to 'spread' the dot more than coated) poor blanket quality, incorrect packings. Dot gain on press wouldn't just affect the highlight.
How are you measuring the dot on plate and on press? Are you running imagesetter or is it CTP?
  • Richard K
    Thank you for your response and sorry for misinformation.
    Here some info. Paper is couche gloss 90 grs, 72 x 96.2 cm, according Komori user manual packaging for blanket is 0.90 m.m and this value was check it using a packging gauge. Our consumables:
    - Blanket: Perfect Dot 4 MX (4MX is write in back side), preasure 60 newton.
    - Ink: Epple premium
    - Dampening solution: Prisco 3551 Plus 2 alcohol free at 5%.
    About pre press, Kodak sell us a Thermal Gold plate wich is a negative plate, we are exposing the plate in a Kodak Creo CTP (trendsetter or Magnus VLF). Harmony is the software use to build dot gain compensation. Our plates are in average +/- 1.3%.
    In next two weeks we are able to swicht to another plate Kodak Electra XD.
    My problem is excessive dot gain in highlight, as I mention before 25% become 43% on paper 50% in 72% and 75% in 89, I don´t know why highlight increase too much.
    Thanks again for your help.
    The paper types 1/2 obviously are the coated paper types described by ISO12647-2.
    These linear dot gains are very similar to what I would expect on our Komori SP40 with 90g coated paper. The lower the grammage of paper the higher the dot gain as the paper is not as stable. Dot gain is not a problem as you compensate for this with your Harmony curves, it only becomes a problem when it is inconsistent.
    If it is higher than previously recorded on the same paper you will need to determine if your plate dot has changed, your ink has changed or your press settings / chemistry have changed.
    Why makes you think the highlights are high?
