Help! Spray attachment won't fire
Discussion in 'Ryobi Printing Presses' started by Al Hussey, Oct 17, 2020.
  1. Al Hussey
    Al Hussey Member
    Oct 2020
    7
    Newfoundland
    Replaced old airtech on ryobi 3302 with new unit now won't fire powder with press running. Works fine on test mode....any suggestions?
  2. Jack liston
    Jack liston Senior Member
    Sep 2019
    275
    Connecticut
    What kind of unit did you replace with does it have a sensor make sure it is clean and in the
    Right position
  3. CHOCK
    2,877
    Please see the Relais R14, is working with 115Vca, if is working with single phase, look for the Fuse F2+f3 and test it if open. if is o.k
    2) see if the Relais R14 is closing when the machine is Running, look for loose wires, lack of voltages, or faulty relais
    Blessing
  4. Al Hussey
    Al Hussey Member
    Oct 2020
    7
    Newfoundland
    Where would I find these fuses?
  5. Al Hussey
    Al Hussey Member
    Oct 2020
    7
    Newfoundland
    Replaced with new airtech...what sensor are you talking about?
  6. CHOCK
    2,877
    Please test this first:
    Blessing
  7. Al Hussey
    Al Hussey Member
    Oct 2020
    7
    Newfoundland
  8. CHOCK
    2,877
    In main panel, to the dude Of Main Transformer.
    Blessing
  9. Al Hussey
    Al Hussey Member
    Oct 2020
    7
    Newfoundland
    Wouldn't have pic or diagram of it...? No idea where to look. Dude of main transformer?
  10. Jack liston
    Sep 2019
    275
    Connecticut
    Look for a small black twist fuse on bottom of the powder unit
  11. Al Hussey
    Al Hussey Member
    Oct 2020
    7
    Newfoundland
    Works fine on test mode..not getting pulse from main board
