heidelberg kord 64
evoprint
HI guys
Does anyone know, what is the required packing for the blanket of the kord 64 and also what should be the width of the ink strip when setting the rollers?
Hi,
Ink stripes should be 4mm to rilsan rollers and 3mm to plate.
The blanket should be bearer height and i think the undercut is 3mm so a 1.95mm blanket has 1.05mm packing.
Hope this helps.
Regards.
  • HI,
    Thanks very much. We bought the machine without the manual not always easy!! I will try these settings soon I will replaced the inking rollers and a blanket.
    In fact I also use a KORD 64 which came without a manual but a experienced minder would know how to get this set up
    sorry for interrupting......
    Since i am a beginner could you explain what is rilsan roller.
    are you referring to the oscillating rollers....????
    thanks
    thanks
    Yes that is correct. Rilsan is the name of the product which Heidelberg coat the oscillating rollers with.
    Regards.
