Hamada 234A
Discussion in 'Print Community General Printing Discussion' started by Knelson, Apr 18, 2011.
  1. Knelson
    Knelson Member
    Apr 2011
    34
    Texas
    I an Running a Hamada 234A, new rollers, Blankets pressures to spec., and it will not run any type of solid or Halftone, Royce Water system with stock water system. ank help
  2. Hamadaman
    Hamadaman Member
    May 2011
    14
    Toronto Ontario
    do you mean hamada matics?? it should run great half tones and fair solids remembering that it is a portrait press. the water units are very finicky and tough to run. most of the 234a that are around have been switched to kompacs. much better and much easier to run. are the ink forms to osc. set properly??
  3. WWW.CPLUZ.COM
    WWW.CPLUZ.COM Member
    Feb 2012
    10
    INDIA
    Dear Hamada man, I am running Hamada H234E, but don't have any manual for this, i am looking for the same. can you help ? thanks
    regards
    n rajendrran
  4. Hamadaman
    Hamadaman Member
    May 2011
    14
    Toronto Ontario
    H234
    here is service manual hope it helps
  5. WWW.CPLUZ.COM
    Feb 2012
    10
    INDIA
    Dear Hamada man, I am very much thankful to you, your support for the service manual is very very useful to me. Also I need Operators manual for the same. Some of H234E functions are not match with H234A. Please help.
    Regards
    n rajendrran
  6. WWW.CPLUZ.COM
    Feb 2012
    10
    INDIA
    Error 1 05 ?
  7. Hamadaman
    Hamadaman Member
    May 2011
    14
    Toronto Ontario
    hi
    error 1 05 is first unit and it says swing unit jam. is there something over the sensor by the feed roll? or the electronic double sheet?? Have you shut machine off and restarted?? i have a op manual and am going to attach
    thanks
  8. WWW.CPLUZ.COM
    Feb 2012
    10
    INDIA
    Dear hamadaman
    you are right. Double sheet adjustment was over threaded and now the problem solved. Also thanks to operation manual pdf. Thanks
    regards
    n rajendrran
  9. WWW.CPLUZ.COM
    Feb 2012
    10
    INDIA
    H234E control panel is differ from H234A. Blanket is not get impression completely. It shows some blank area here and there.
    hi hamadaman
  10. Hamadaman
    Hamadaman Member
    May 2011
    14
    Toronto Ontario
    good morning
    if you are getting some impression that should mean its coming on. are you getting imp from plate to blkt cyl?? if not it may be bad blkt.or not enough packing. where are imp dials set?? try at put them to 0.3 then bring up to 0.1 as you are running if imp gets better i would go for packing or blkt. i usually over pack by 3 to 4 thou.
  11. WWW.CPLUZ.COM
    Feb 2012
    10
    INDIA
    Dear hamadaman
    The leading edge clamp of EPS plate moulding unit. On four L key screw the thrid was broken and the plate was not fitting tightly. I try to replace the screw. but i dont know how to remove the edge clamp. Please help if you have any idea.
    Regards
    N Rajendrran
  12. WWW.CPLUZ.COM
    Feb 2012
    10
    INDIA
    Dear hamadaman
    My HAMADA H234E - stopped on Error - 108
    Error - 108
  13. WWW.CPLUZ.COM
    Feb 2012
    10
    INDIA
    Error 108 - 1st impression unit sensor error
    Error
    1 08
  14. WWW.CPLUZ.COM
    Feb 2012
    10
    INDIA
    4mm & 25mm total length (incl. head) allen key
    Hi everybody,
    Need 4mm & 25mm total length (incl. head) allen key screw needed for Plate tight
    Regards
    Rajendrran
  15. Turk
    Turk New Member
    Mar 2016
    mgl
    Hi Hamadaman
    Do you have any manual of Hamada C52e? Please help me to find operation and service manual of Hamada C52e
  16. RIBEIRO2020
    RIBEIRO2020 New Member
    Aug 2020
    brasil
    ola, alguém que tenha a hamada 234a poderia por favor postar uma foto da posição dos dips da placa de I / O? ou só me falar aqui qual esta em on e off. A minha aqui os rotativos estão em s1: 5 e s2: 4 e os dips somente a 8 esta on. Alguém me ajude por favor. Outra coisa, a máquina não libera pra ligar, a luz da campanhia fica apagada, tem alguma coisa na máquina além dos botões de stop (pois já conferi todos) que bloqueia a máquina de ligar e picotar?
  17. RIBEIRO2020
    Aug 2020
    brasil
    hello, could someone with hamada 234a please post a picture of the position of the dips on the I / O board? or just tell me here which is on and off. Mine here the rotators are in s1: 5 and s2: 4 and the dips only at 8 is on. Somebody help me, please. Another thing, the machine does not release to turn on, the bell light is off, is there anything on the machine besides the stop buttons (because I already checked them all) that blocks the machine from starting and perforating?
