Epson 9880 prints too short on one printer
Discussion in 'Large Format Inkjet Printers' started by swbshogun, Nov 14, 2017.
Tags:
  1. swbshogun
    swbshogun New Member
    Oct 2013
    Wales
    I've got two 9880's and the length of the prints on one printer are too short.
    If I print say an 800mm image on one then it comes out 800mm long but if I print on the other it comes out about 795mm & banding can be seen on the image. Not only that but if I measure the image side to side there is about 2-3mm difference in length.
    Both printers are set exactly the same, same firmware same driver etc & I have done a factory reset on the one causing the problem along with a full head alignment just incase, but cannot figure out what is causing the problem.
  2. swbshogun
    Oct 2013
    Wales
    Forgot to mention that the thicker the media the worse the problem. 80gsm matt paper prints pretty close to the required length but 200gsm is what i was using in the above tests
Share This Page
