Duplo System 5000 Error Code
Chris Munch
2022
5
Dayton, OH
We have two towers, when turning on the second tower gives "f940got-e" error code then shows then the main screen but with no text. But, a light on the control panel comes up which indicates the conveyance board is open (which it is closed).
Have tried cleaning/checking wires but could be missing something/somewhere.
Any suggestions? I've seen some posts in the past similar to this.
Hello! I'm not 100% sure, but maybe you have a bad battery (and firmware was lost)
  • Hello
    There ia a battery at the back side of the touch screen under a plastic cover.
    Pls replace it and after that I'll send you details about the parameters adjustments of the
    touch screen.
    Sounds F940WGOT. like your program does not have a screen 0, which it is being told to display from the PLC registers. make sure the the PLC registers which store the currently displayed screen number contain a number that is a valid screen number.
  • Hi, sorry for my delay.
    When you turn on the machine wait some seconds and after that it will show the
    graphics of duplo without numbers.
    Touch the screen at upper left corner of the screen and will appears
    the menu of the touch sreen.
    1.other mode
    2.setup mode
    3.plc type in that menu you have to set: universal and rs232
    4.end
    5.opening screen :you set that 0 sec
    6.end
    7.serial port :you set
    9600bps
    8bits
    1bit
    none
    xon/xoff
    8.end/end until to get out.
    Turn off and on the machine.
    Hello,
    I have a problem with DBM-500 also, please see attached photos. Does anyone knows how to resolve this issue!?
