DRUMS Xante Ilumina 502; Intec 2020; Xerox Phaser 7400, OKI C9600/9800/ES3640/CX3641
OkiTech
2008
833
NEW JERSEY
We have OEM DRUMS that will work in following machines:
XANTE ILLUMINA
INTEC 2020
XEROX PHASER 7400
OKI C9600/9800/9650/9850/ES3640/CX3641
SHARP AR-C360
LUCIDIUM 9800/9850
These are Original Drums designated for LUCIDIUM 9800/9850 brand but with removal of Key-Plate on the back wall of your printer (1 screw, picture attached) you may make your printer accept any drum from any model listed above as they're all, essentially, based on the same OKI chassis/engine.
Black - $115
Any C/M/Y - $135
SET CMY - $375
SET CMYK - $480
Prices include Ground shipping within mainland USA
  • Hi thanks for your interest.
    CMY Drums are $165.00 ea, Black $125.00
    CMY Toners $145.oo ea, Black $95
    Belt is $185.00, comes with waist toner container
    No fusers at the time.
    While supplies last
    Hi
    I'm looking for a 4 set of drums for my Xante Illumina 502.
    Question 1 : Do you have any in stock and if so what are the costs..?
    Question 2 : Do you ship overseas (New Zealand) and if so what are the costs and if not can you recommend any place in NZ / AU where I can get drums from?
    Thanks in advance
    Cheers
    Andrew
    Can you recommend alternative waste toner units for xante illumina 650. I am struggling to find genuine xante stock in the uk
    Xerox Phaser 7400, OKI ProColor 900/910/920/930, OKI C9600 / C9650 / C9800 / C9850, OKI ES3640, OKI CX3641, Intoprint DP100, PSI LM3640, INTEC CP2020/CX2020
    all have same Waste Toner Bottle, Fuser and Belt
    I know this is an old thread but I’m looking for Xante Ilumina 502 image drums, specifically magenta. I’ve looked many places and have “found” them numerous times only for the supplier to message after to report it’s our of stock and cancel. Anyone know where one could find a magenta drum that’s not price gouged?
    Yeah, welcome to 2022 where everything is Biden-ouged, or sorry price-gouged except booooosters, those are forcibly-free. Have you see gas prices lately? :) car prices?
    Anyway, Magenta is most desired color, I will take a look if I have any left. If not, would you be interested if I show you how to use any OKI type C7 drum in your Xante Ilumina?
    You, realistically, can use OKi c9600, C9650, c9800, c9850, es3640, cx3641, proColor c900DP, xerox Phaser 7400 drums in your printer, the other supplies as well, as they all made by OKI, most likely came off the same production line.
    Bwahahah. I figured it was because of that! I’ve also been searching for the equivalent alternatives too. But to answer your question- yes I would love to learn how to convert the other brands to work with my Ilumina. I would be interested in those if I can get them to work. Just let me know. Thanks!!
    Ok, to make your Xante ilumina a "universal drum recepient for any type/btand of C7 type drum" you will need a philips screwdriver preferably magnetized, little side cutters and some clean cloth-rags.
    1) take all drums and belt out
    2) you will see 4 back tablets/thingies on the backswall of the printer held by 1 screw each.
    3) lay some clean towel/cloth in such way that if screw falls, it will be on the rag, not fallen down and rolled in the printer's cavity where you'd never find it :)
    4) Note that 2 of those thingies are just there and 2 are holding some white plastic Lshaped pad jammed in to the opening with its other side.
    5) those tablets-thingies that do not hold anything, remove and discard
    6) those tablets-thingies that holding white piece, remove, trim of the top with sidecutters (as pictured) and reinstall.
    7) Congratulations, now your printer can take drums from:
    Oki C9600, C9650, C9800, C9850, ES3640, CX3641, ProColor 900DP.
    Xerox Phaser 7400
    8) only thing you'd have to do every time you use non-Xante branded Drum, in Toner Cartridge landing area, there are 4 pins that have to correspond/engage properly with the same 4 pins on the bottom of toner cartridge. They snap in and out, take little pliers or same small sidecutters, pull'em out on drum side and snap them back so they do properly engage with those on the toner. Takes 15 secs.
    Thats it.
    That’s super helpful! I greatly appreciate all the help! Does anyone know where one could find me a magenta drum?
    Which pins, the ones that correspond with toner cartridge?
    This is picture of pins on toner cartridge, pins on the drum must be opposite of these.
  • Not sure what i'm doing wrong but I keep getting service error 142 and when i restart, it will somtimes display service error 145.
