1) Test the input for L1+L2+L3 and see if there in tolerance in 10% up or down, it does NOT matter if you have Input for: 220Vca or 380Vca or 440Vca.
2) Measure in the electronic BLT in the terminals L1+L2+L3 , If they are Input of voltage in TOLERANCE as i did indicate go.
3) Measure the U+V+W For Output Main Motor, that is the Input to the main terminal of Main MOTOR, and compare with the ID Plate of the MAIN Motor if there are o.k or NOT.
4) At the same time measure +24Vdc for Brake, this device is controlled electronic via BLT.
5) Look for loose connector, dirty, grease, corrosion, or break wires, Reset the C. Breaker for Main Motor, look for the Schematic Diagrams Electrical, or Fuses if they uses, and see if there are OPEN, or faulty, or terminal corroded+ look carefully if they are some electronic components burn, or overheating, or corroded, or Colder+Dry join solder, clean very well, of Course Turn OFF the machine, for to do this inspections and Test.
