CP2000 keep restarting mostly after running startCP2000
Can you run the machine from feeder start button or unit productin button. Most probably hdd or software issue.
For anyone who might be interested, I found a solution to a similar problem, the 12 volt rail on the atx powet supply would drop down below 11.5 volts causing a restart.
  • The problem is I have Heidelberg display stucked on the sm52-4, cp2000 screen and the system does not load beyond that.
    Its 00.783.0758/02
    MC3-C-BR-03
    169339
    I have tried running the Primary Slave /1 to 2, or 2 to 1 both/
    I would be very happy to have someone to advise me.
    Press an emergency stop on the delivery panel, does the blue light start flashing? If no then there is no connection coming from the press.
    Share a picture of where the screen is stuck that would help also, you might need to do a software re-install.
    However i recommend you to Reset the Cpu or Microntroller in the Main Board.
    Attached is there my schematic diagrams, for to do it Reset +Example of 8085 CPU , see carefully, and search in Google according with his CPU or Microcontroler that main board has, the Pins schematic, in order to carry the RESET, but
    1) you must measure the Power supply or Vcc for CPU or Microcontroller
    2) Clock of Cpu or Microcontroller, any of those if there are out or faulty, the Cpu or Microcontroller Will NOT the Press with All this errors Showing in the Screen.
    3) Please do Not be afraid, with this Test, You will loose any information from his machine, only you will test 2 things with this steps.
    4) a) If the power supply +Clock x CPU or CPU= is Defective b) or The Software or Programs or Firmware is Corrupted!!
    Blessing
    Thank you so much to everyone for the advice.
    I will try according to the instructions and respond.
    Thank you.
