Coater blanket
Discussion in 'Heidelberg Printing Presses' started by Drbevan, Jun 24, 2015.
  1. Drbevan
    Drbevan Member
    Jul 2011
    30
    Perth, Australia
    Hi All,
    can anyone shed light on why the coater blanket on XL75 picks up quite a lot of ink. We run with medium weight anilox an have the pressure backed of until just kissing, ink is building up and we get 2 heavy horizontal strips that are thick.
    Any ideas are appreciated.
  2. boooch
    boooch New Member
    Aug 2014
    Russia
    Hi! You can pictures to post? What anilox you have?
  3. Jruff
    Jruff Member
    May 2014
    13
    New Jersey
    Sometimes we experience that if there is a light film of coating on the blanket while there's a lot of ink coverage on the job. Increasing the flow of coating % usually alleviates the issue.
  4. mrheidelberg
    mrheidelberg Senior Member
    Jan 2008
    648
    United Kingdom
    That cannot be done on an anilox roller equipped machine, the only way to increase / decrease the coating is to change the actual anilox roller.
  5. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    826
    Vermont
    do you monitor the flow of your coating with a Zahn cup before pumping it up to your coater? Id begin with that and then if the problem persists id be looking at your annilox roller for clogged cells and also if its the right roller for what your trying to do.
  6. aqazi81
    aqazi81 Senior Member
    Oct 2009
    821
    KARACHI PAKISTAN
    Few possible causes...
    Coater activating late, allowing ink to transfer to
    coating blanket at start-up.
    • Excessive pressure between blanket roll and
    impression roll causing squeeze out of coating
    and pick up of ink on blanket
    • Insufficient amount of coating being carried by
    blanket.
    • Ink volume too great for single station
    application or to allow sufficient bodying before
    coating application.
    • Ink tack too low, producing a weak strength ink
    film.
    • Excessive water pick up from fountain solution
    by ink causing extended open time and ink film
    weakness.
    • Coating not rewetting properly.
    • Blanket too soft or tacky due to having been
    washed repeatedly with petroleum solvent.
    • Improper blanket cleaning or possible
    contamination.
  7. Ade
    Ade Member
    Dec 2013
    32
    N/A
    Yes I would agree with that
    If you are backing the pressure off the blanket to impression cylinder,
    are you setting the pressure of the anilox roller to blanket?
    is the under packing correct, is the blanket thickness correct?
    if you are using under blankets is it fitted correctly should be white side up black to impression cylinder,
    what consumables are you using? cheap blankets and coating may be causing your problem.
    are you using the clean off facility at the end of the run?
    is the anilox roller clean how often do you send it away for cleaning?
  8. Drbevan
    Drbevan Member
    Jul 2011
    30
    Perth, Australia
    Thanks for all the help, will investigate the possibilities.
    Regards.
  9. drayprintman
    drayprintman Member
    Jun 2015
    5
    15,olarewaju street orile agege,lagos state nigeri
    if the suction pipe is not sucking the coating well or the coating have finish
  10. Ade
    Ade Member
    Dec 2013
    32
    N/A
    Just a thought it is some thing we had a long time ago have you changed the Anilox roller?
    If you have you gone from light roller to a solid roller the bearings may not be designed for the solid roller as it is heavier and can cause some wear which could show up as some ovulation which could possibly show up as lines on the blanket?
    just thought!
  11. Drbevan
    Drbevan Member
    Jul 2011
    30
    Perth, Australia
    Thanks Ade.
