Casebound covers: checking artwork at the hinge before approval
Baron Wang
2026
15
Shanghai, China
A flat cover proof makes a title or thin border near the hinge look easy to judge. I'd also want to see it on a case made to the intended construction, opened and closed, before approving its position.
For that check, I'd keep the artwork revision with the case sample and distinguish the board edge, joint and turn-in on the layout. A generic safe margin may not describe that particular construction.
How do you normally show a customer where the hinge will sit: an annotated flat proof, a wrapped dummy, or both? What do you check again if the board or covering material changes after approval?
