Can't trim gloss laminated sheets
Discussion in 'Gloss Coatings' started by Dyrck, Jul 26, 2019.
  1. Dyrck
    Dyrck New Member
    Jul 2019
    Christchurch
    Recently we have started having problems cutting gloss laminated sheets on our guillotine. The pressure from the clamp makes the sheets 'block' together into a solid lump. They are so stuck together that often the bottom sheets tear away as the trimmings are pushed sideways by the guillotine blade. once the pressure of the guillotine clamp is removed it is simple to fan the sheets out and they are fine. We are using BOSS digital OPP film
  2. conal
    conal New Member
    Aug 2019
    ireland
    digital films have a terrible static build up in them ,aireate the sheets before and after and cut in smaller piles should help, also if you can try move away from digital films they are notorious for giving problems
