Blanket Loosening
Discussion in 'Komori Printing Presses' started by Richie, Mar 21, 2017.
  1. Richie
    Richie Member
    Feb 2010
    52
    south africa
    Hie guys am running a Komori LS40 and am having a problem with the first unit blanket getting loose during the run. I have to tighten it after about every 1500 impressions. Called in an engineer and he said it was the spring on the blanket tensioning bolt. He changed it but still the problem is there. Please help guys.
  2. jef
    jef Member
    Oct 2015
    36
    canada
    Maybe too much pressure plate to blanket, blanket to impression?
    er.bajaj001@gmail.com likes this.
  3. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,054
    Vermont
    are you sure the blanket is not pulling out of the clamp?
  4. Richie
    Richie Member
    Feb 2010
    52
    south africa
    Thanks guys for your responses the problem was solved by loosening the worm gear holder and pushing the worm gear to the other gear and we tightened it.
