cpJuan
I'm having issues with my Quickmaster Classic not wanting to feed paper correctly all of a sudden. One day I'm printing 12pt paper with ease and the next day I cant get the machine to feed a sheet or two without the press stopping because the paper didnt go through. The pump has a different sound as well and I have inconsistent vacuum and very very low air separating the sheets at the front of the feeder. Its so bad that it cant feed 20lb paper sheets because the machine can't feed the paper consistently without stopping. My setup is good, paper timing is good and the feed table is going up when it should but the machine just doesnt want to feed the paper correctly. There just isnt sufficient air/vacuum.
I cleaned the two filters at the pump but they were relatively clean since I cleaned them not too long ago. I've looked for loose or unplugged air/vacuum hoses but everything is on tight. Does this sound like a bad pump to you guys? If so, anyone near the Los Angeles/Inland Empire area have a spare one for sale? Also, what exactly does the 3-2 valve do? Does it just control the vacuum going to the suckers? Should I clean it and grease it? Any help is greatly appreciated.
Thanks,
Juan
Thanks,
Juan
