wohlenberg spm76
Discussion in 'Cutters and Trimmers' started by samy1990, Apr 20, 2021.
  1. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    hi everyone. in the cutter paper wohlenbergspm76 I have message on the screen (p-err), is anyone know what is it means ?
    2,896
    Hi sir;
    Please do this:
    Miroslav Tassev likes this.
  3. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    hi
    Thanks for your reaction ... 1 .. What is the service button icon?
    2 .. When power on the code is(ready) Shows and when stirring appears are correct. But when i try to work with an automated with a new distance storage, i receive a message (p-err) after pressing (M) and does not storage the space and does not move
  4. CHOCK
    2,896
    You will find this- service button on the left-hand beside the display behind a small hole in the front panel and it can be activated for example with a match-stick.
  5. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    I will check this and I will tell you the result ... thanks for your cooperation
  6. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    hi sir
    after press service and no cut potton the display is (ready) and nothing changed !
  7. andy martin
    andy martin Member
    Aug 2016
    98
    bradford po
    P-err usually means when joystick moved to automatic and programm run button pressed joystick microswitch not seen, probably faulty
  8. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    hi sir....immediately i test the micro switch it is good
    this message (p-err) appear when i press(m) to save my new distance and the joystick at (A)
  9. CHOCK
    2,896
    Test the battery lithium, by 3.6Vdc, if is low replace it, with the same type
    you have only 10 minutes , otherwise you can loose all Information in RAM memories.
    2) Please, test all power supply from Vdc, +5Vdc+24Vdc, in tolerance with 0.7% up or down, otherwise, replace o repair, the cutter will NOT work, in any way, do it carefully, according with his schematic diagrams electrical, and Good tester DMM.
  10. andy martin
    andy martin Member
    Aug 2016
    98
    bradford po
    Hi first does the machine cut in manual, can you use existing programs. If so then maybe memory full
  11. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    nothing at all in the memory.... I try to write new program and save it... but i failed.... the machine just work manually
  12. andy martin
    andy martin Member
    Aug 2016
    98
    bradford po
    Do you know how to insert the machine parameters. If not give your e mail address and I will email how to do this
    samy1990 likes this.
  13. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    Yes, please with thanks
  14. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    Hi sir
    I will test it
  15. CHOCK
    2,896
    Hi sir;
    Ok, test very well.
  16. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    I received your message gladly, I looked for a lot about this file ..
    I expected to put the company the error messages like my message I mentioned earlier (p-err) ...
    Whatever the case thank you very much Doctor for help
  17. CHOCK
    2,896
    Your welcome,
    Proceed with my steps .....! remember use the ¨ Common sense¨ most invaluable tool for troubleshooting o.k
  18. samy1990
    samy1990 Member
    Apr 2021
    18
    syria
    my dear friends
    i test all voltages and the switchs of the juystick and switch of came and the computer battery 3.6 v ...all is good :(
    computer don't save my program and don't appier N 2 .......
    the potton of starting the program is ok
  19. CHOCK
    2,896
    send me pics of th each voltage with the DMM. please??
    Reset the Cpu see the schematic attached, and search Google, or Yahoo, or Bing etc, according wih the Cpu or microprocessor the pins schematics for the Microprocessor or CPU.
  20. Gustavo Maidana
    Gustavo Maidana Member
    Sep 2021
    7
    ituzaingo
    Good morning, I have a problem with a Wohlemberg guillotine, the battery discharged and everything was erased, I got a reset plan and managed to recover some things, but I can't get the squad ready, start the machine I take it to the point of reference (50cm) and then I can bring it forward but it does not go backwards, I cannot use any program because the rule is not correct, I do not know how to regulate this, could you help me please
    Greetings from Argentina vikipopower@gmail.com
