lyndsaym82
- 2012
- 1
- Australia
Hi there, I am new to the forum; I hope I may be able to ask for advice about my printer. I have searched and haven't found a similar question before, my apologies if this issue has been addressed previously.
I have owned a Xerox Phaser 7760 for about 4 years now, and for the life of me, I cannot work out how to fix a reoccurring issue of quality when printing. Please note, I must admit to not knowing a lot about colour profiles and certain terminology, but I'm happy to do some research if it's recommended in order to clarify my questions.
I use all Xerox-brand toners and paper. I notice that the print of my files (usually Illustrator-generated design files (.pdfs) or InDesign files) has a "pixelly" quality - type appears blocky; lines are not smooth, etc. What I am printing is 100% vector - which makes me think that it isn't an issue with low-quality images.
Along the same lines, larger blocks of colour often appear grainy and uneven. I also find it really hard to get a consistent colour - when printing 60 of a file, I will be lucky if 20 are the same shade of blue, if that makes sense.
I have previously played around with the settings in the printing dialog - working with different print qualities ("standard", "enhanced", "photo") which only seemed to yield a difference in the colours, for example a richer pink in "enhanced", lighter pink in "photo" and "standard"). I don't think I'm on the right track with adjusting these but I'm not sure what else to do.
I don't have massive expectations for a print as good as a commercial print but I would like the printer to print to the best that it can - it's an expensive machine here and quite costly to run, and I print for clients who have made mention of this issue as well which isn't a great feeling.
I wondered if anyone with more experience with the printer may recommend any tips for getting a better quality of print - does this sound like a memory issue, or something I can adjust in the settings?
Many thanks in advance if you're able to assist,
Lyndsay
Lyndsay
