ScottWashburn
- 2011
- 2
- Philadelphia, PA
Hi! I have a Xerox Phaser 7400 printer and the LED panel on the controls has gone out. I'm getting a replacement, but I need help in continuing to use the printer until the replacement shows up. Specifically, I need someone to tell me the sequence of paper types and sizes when you put new paper into the side feed tray.
Going from memory, when you put the paper in you get a message asking if you want to use the same paper (default choice, just press OKAY) or if you want to change the paper (press down button once and then OKAY). If you select change paper then you get to select the paper type. Plain paper is at the top, but what comes next? I need to get down to Heavy Cardstock, but I don't know how many clicks down I need to go. Can anyone help? Then once I pick the type, it asks what size. Currently the machine is set on 8 1/2 x 14 and I THINK that SE 8 1/2 x 11 is just above that and 11 x 17 is just below. Can anyone confirm?
Thanks so much!
Thanks so much!
