Xerox Igen3 : sheet attached to the web in the press
Discussion in 'Xerox iGen3, iGen4, & iGen5 Digital Presses' started by salvo1486, Oct 4, 2014.
Tags:
  1. salvo1486
    salvo1486 New Member
    Oct 2014
    Italy
    Hi, I'm a new user and I write from Italy. I have a problem with the printer iGen3. Use for printing paper A4 80 gr (not xerox paper) when printing simplex there is no problem but when you print on the side two the sheet remains attached to the web. May depend on what? I state that the temperature and humidity are optimal and has always printed with the paper stock with no problems. help me. Thanks. Sorry for my english ....
  2. peels
    peels tree killer :)
    Dec 2010
    1,113
    southeast iowa, usa
    to the PR belt you mean?
    I would try swapping transfer corotron?
  3. salvo1486
    Oct 2014
    Italy
    Yes, I meant the PR belt. I have already swapped transfer corotron but without success.
  4. Neess
    Neess Senior Member
    May 2011
    165
    Aarhus, Denmark
    You do have the stripper fingers mounted?
