xerox 800 watermark problem
Discussion in 'Xerox Digital Presses' started by Shawn, Jan 29, 2019.
  1. Shawn
    Shawn Member
    Jan 2018
    23
    Toronto,Canada
    Hi,
    recently our xerox 800 printer has watermark problem.see the attached pictures, the first print look pretty good, but after print 5 sheets, more and more white dots coming.
    I think its the fuser problem, so changed fuser belt and oil wick according to the service manual.
    but still the same.
    any solution? thanks
  2. Kringle
    Kringle Member
    Oct 2013
    61
    California USA
    Have you looked at it under a magnifier?? Could be paper dust from dirty paper. I think the first thing I'd try is to swap out stock and see if I can replicate the issue on new clean paper.
    Also, look at the ibt belt. See if you can see any dust or anything on it. When I'm having imaging issues, I like to put binder clips (interlock cheaters) on the main front doors, run about 20 sheets, after a few sheets have exited, pull one of the clips to simulate opening the door. This way, you can inspect the sheets in all different sections of the machine to see where it might be happening. If the sheet before the fuser has the dots, then you know your problem is not in the fuser. You can also inspect the ibt belt at the same time as it should have at least 1 impression of your image still on the belt.
    Hope that makes sense.
  3. Shawn
    Shawn Member
    Jan 2018
    23
    Toronto,Canada
    thank you Kringle, I switched paper, doesn't work.
    make hard stop to check. and its fuser problem for sure. before fuser, everything is good, after fuser the dot come. any idea?
  4. Kringle
    Kringle Member
    Oct 2013
    61
    California USA
    You want to ensure that everything in the fuser is clean. So do a full service if you did not. All of the rollers through the fuser and under the belt can get black gunk built up on them. We use Windex (only on a cool fuser) and paper towels to slowly work it all out. Also, inspect the sheet pad. That's something that is usually replaced along with the oil wick and belt. Also, inspect the large rubber pressure roller at the bottom to make sure it's clean and spins easily.
    When you scratch at the surface of the stock with a thumbnail, is the toner fully fused or is it scratching off easily?
  5. adriansto
    adriansto Senior Member
    Apr 2011
    138
    somewhere in europe, near Black Sea
    Check the pad from fuser belt assy.
    Good ideea to replace the pad.
  6. Biggs
    Biggs Senior Member
    Mar 2017
    209
    Edison, NJ
    Initially when I read "white dots" i thought for sure it was something stuck on the transfer belt. but that picture... No belt would become that contaminated.
    I'm curious, is that an uncoated media? Accent or cougar, Lynx, etc?
    Is it duplexed or face down output? maybe the toner is separating on the second pass...
  7. Shawn
    Shawn Member
    Jan 2018
    23
    Toronto,Canada
    Hi,there
    I did the fuser cleaning completely, still the same. so I was very frustrate. but I changed paper stock setting by increasing the thickness, for example, 100lb gloss text from 157gsm to 200gsm. the problem is gone!!! (but the same paper, same setting which works fine before.)
    but I still want to change the pad assy. according to the service manual, pad assy and oil wick should be change at the same time.
    where do you order parts from? any good online store or supplier?
    thanks you all
  8. Kringle
    Kringle Member
    Oct 2013
    61
    California USA
    try searching Alibaba or look on ebay or you can just order direct from Xerox parts.
  9. Dio
    Dio New Member
    Apr 2019
    USA
    Ever find a solution for the fusing issues?
  10. Biggs
    Biggs Senior Member
    Mar 2017
    209
    Edison, NJ
    It may very well have been the transfer voltage after all. Increasing the GSM will indeed increase fusing temperature, but the more significant internal adjustment would be to secondary transfer voltage.
  11. Back in 2017. I’ve been faced the most similar issue, after struggle I found the way to get rid from this watermark problem.
    There are two solutions.
    1. Replace the cartridge that is producing the coloured squiggle/
    2, dismantle an OLD cartridge and if it has a plain (non-spiral) foam roller, swap that (along with it's supports - the new type are a different size).
    Either of the above will cure the problem, but a new replacement cartridge may also show the problem in time, as it WILL have the spiral cleaning roller.
