xerox 7232 M C K light banding on solids at 2mm regular intervals
tech9
2010
london
Hi i have a 7232 doing light regular banding more noticable on solids so the the density looks uneven. Yellow is ok but magenta,cyan and black produce light bands top to bottom at regular 2mm intervals. All developer tanks have been replace, Ros changed, 2nd BTR, Drum and IBT belt assembly ?
Well i think you have to check hvps and also check the developer housings that is located under the ibt assembly . I could help you if you send and example of the problem
  • Sorry i I meant that the hvps is under the ibt assembly
    Thanks i will bare it in mind, but for now the customer is ok as it is bareable.
