x2f-08-3103
Discussion in 'Xerox iGen3 & iGen4 Digital Presses' started by peels, Oct 27, 2017.
  1. peels
    peels tree killer :)
    Dec 2010
    959
    southeast iowa, usa
    horizontal transport motor failed to start. A1, so i cant run just one feeder unit.
    wont get past this. Any idears? did some reseating of some plugs back there, to no avail.
    Of course, I'm off half day tomorrow, and have a weekend trip, with much to get done :/ dangit Genny, you have the worst timing!
  2. peels
    Dec 2010
    959
    southeast iowa, usa
    got it going through restarts, reseating plugs.... then it came back yesterday. just reset the error about 20 times, it finally cleared. running again but Im sure it wont be long :)
  3. Kiran04
    Kiran04 Senior Member
    Aug 2014
    137
    Santa Fe
    You sure it's not the transport rollers? Last time I had that error it's because every transport roller on the feeder had an indent in them where they had been resting, producing massive drag on the motor. The yellow rollers are crap. If you have them, order black ones that don't form grooves.
    peels likes this.
  4. peels
    Dec 2010
    959
    southeast iowa, usa
    yeah its telling me its missing 36 volts on the feeders too. Pretty sure its electrical. it fails to start up...
    thanks though! will definitely keep that in mind, Igen is gettin so old
  5. peels
    Dec 2010
    959
    southeast iowa, usa
    this ended up being a board. DSC? dropping 36 volts from a couple ports at random. swapped with A2. works fine
  6. Milo Wilson
    Milo Wilson Senior Member
    Dec 2007
    361
    Arkansas
    Have you tried cleaning all the pins on the board with some de-oxit electronic cleaner and re testing?
  7. peels
    Dec 2010
    959
    southeast iowa, usa
    yep cleaned everything I could get to. ;)
    like I said, apparently, just a bad board. Which I kind of figured, when the 36v errors started to move around the different systems... vertical, horizontal, feed....
Share This Page
