Wohlenberg error
Danielf36
2022
Hermosillo sonora
Help me - on my wohlenberg 115 guillotine a failure icon of two hands misadjusted appears.
Hello, can you tell me the exact model of your Wohlenberg 115 guillotine? Cut tec?, High Speed
  • Hello, it's cut tec.
    I appreciate that you answered me quickly.
    I have a lot of work stopped.
    Good evening. I imagine that the problem you have is that the blade does not go down?
    Well, I don't understand your term Misaligned 2-hand staple failure???
    Please, I need you to explain exactly what your problem is.
    1) Well, if the problem is that the blade does NOT go down, you should check the clutch carbons of the machine, and see if there is voltage, according to your electrical schematic diagrams, and see if they need replacement, or cleaning and adjustment of the carbons, and the clutch rings.
    2) Check the cutting buttons, if they are ok, or dirty, or defective, check if there are loose cables, or cut, or if there is voltage to the cutting buttons for the blade.
    Is there an error on your machine?
    If it appears, press the F8 key to do a Reset.
    Good morning,
    I continue with the problem of the guillotine; the blade does not lower when I restart the machine. A legend appears that says the FE format program buffer has not been found, yes or no.
  • Hi sir;
    I did various questions.
    and i gave some solutions. did you do sir??
    Let me know, the fact that you restart the machine, WILL NOT fix it. sir.
    Please proceed with the steps, that i did indicate you, You did not mention anything
    Do it, and back to me, if the steps does NOT fix it.
    Good morning,
    I need help with this error code.
    cutter wohlenberg 115
    Year: 2005
    Number: 3896-013
