What are the causes of this problem
Discussion in 'Heidelberg Printing Presses' started by ali 120, Nov 24, 2023.
  1. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    What are the causes of this problem or is this normal?
    When the pressure in the blanket cylinder increases
    The distance between the blanket cylinder holder and the plate cylinder holder is reduced
    Note that the use of this indicator has no relationship between the plate cylinder and the blanket cylinder
    https://www.raed.net/file?id=498898
  2. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    It is ok pal
  3. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    What you mean is that the increase and decrease that occurs between the blanket cylinder holder and the printing cylinder holder is very normal with the movement of the paper press indicator.
  4. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    By increasing impression you decrease the gap between blanket and impression cylinders. And when you decrease the impression you increase the gap
  5. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    But what I know is that the increase in impression has nothing to do with the blanket cylinder and the impression cylinder, because each of them has a different path from the other.
  6. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    So HOW do you increase impression???
  7. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    I mean that increasing the impression index has to do with the paper and has nothing to do with increasing or decreasing the gap between the blanket cylinder and the cylinder above it.
    Because each of them is separate
  8. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    I give up:(
  9. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    Look, you're printing job on 0.06 paper. Your next job is on 0.5 board. What are you doing?
  10. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    I mean between the two holders marked with blue arrows
    When I increase the index, the impression on the paper increases, the gap between the two marked holders decreases
    When the indicator is reduced, the gap between the two carriers marked by blue arrows increases
    https://www.raed.net/img?id=499446
  11. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    I ask you to be patient
    Because I am not good at English
    Also, the terminology you use is not the common terminology in my country
  12. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    I'm more patient than ever mate :D
    So, there should be no gap between plate and blanket bearers during printing. These cylinders are printing bearer to bearer.
    The gap should be between blanket and impression cylinders - that gap is depend on paper thickness - thicker paper - bigger gap.
    Can you put measuring gauge between plate and blanket bearers when impression is engaged?
  13. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    Should I do something like in the video?
    The filler used is 0.10%
    There are those who say that feeler gauge 0.50 mm should be placed between the blanket cylinder holder and the painting cylinder holder.
    The machine is in non-printing mode
  14. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    If impression is disengaged (non printing mode) there should be a gap between plate and blanket bearers. Otherwise image would be transferred to the blanket all the time.
    But let's start from the beginning - have you got any issues with printing, or you just concerned about how big gap should be?
  15. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    There is a problem printing
    I made a topic about it
    When the paper is put to print for a second cycle, there will be dark and light colored paper
    First, I want to check the level of the blanket and between plate
  16. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    Oh yes now I remember. That may be nothing wrong with the machine. Have you taken that picture of whole sheet?
  17. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    Unfortunately, I did not find a photo of the entire paper
    But I will pick it up and send it to you
    I want another request from you
    Is there a catalog for how to adjust the blanket cylinder holder with the cylinder holder above it?
    https://www.raed.net/img?id=499702
  18. mantman
    mantman Senior Member
    Nov 2015
    272
    Greece
    The dial you turn is for impression ONLY. Plate and blanket is FIXED from factory and not to be tampered with!
    Take the 0.35 mm filler and put it between blanket and impression bearer ring -holder what you call it-, then engage impression turn one revolution -like putting a plate-. It should move with a slight drag. If you cant put it between bearers or it moves freely then turn the dial until you find the proper drag. After this loosen a small 3mm allen screw, take out the dial and put it to 0 position -turn by hand- put it back in tighten 3mm screw and you are ready
  19. Rui Pereira
    Rui Pereira Member
    Nov 2023
    16
    Mozambique
    Its normal...if u know how it works the pressure on those type of press machines. Theres a single pneumátic jack do the 2 moves needed to print...1 move to the plate cilinder, the 2 move...if you increase the pressure, that means that the blanket cilinder need to be more close for the impression cilinder, but the plate cilinder automaticly adjust the vão between them...the Gap between the blanket as to BE always the same...
  20. ali 120
    ali 120 Member
    Jan 2023
    71
    Egypt
    When the blanket cylinder index increases
    Reduces the gap between the pallet cylinder and the blanket cylinder
