Waterless Printing
Discussion in '4-Color Offset Presses +' started by birdiez, May 20, 2009.
  1. birdiez
    birdiez Member
    Mar 2009
    5
    USA
    Who's got experience with waterless printing? I'm curious to know what the industry thinks of this technology. :confused:
  2. 5150pressman
    5150pressman Senior Member
    May 2008
    113
    san francisco bay area
    It was suppose to be the next big thing in printing in the 1990's.
    Some shops got it to work well while others gave up.
  3. pressman57
    pressman57 Senior Member
    Mar 2009
    52
    SanDiego USA
    From what I heard the plates were way too easy to damage and were impossible to repair.
  4. RichardK
    RichardK Senior Member
    Aug 2007
    685
    Derby, UK
    I tried Toray in the mid 80's...sounded too good to be true..it was!
    The tack levels were too high for the substrates we were running (packaging boxboard) and we ended up delaminating the coating from the backing a lot of the time.
    However I'm told that things have moved on a pace and, if you're prepared to stick with it, it can give very good results at high screen rulings.
    Inker temperature control is a must.
    I'm not sure if there are PMS or metallics in the range or if it's just process inks.
  5. 5150pressman
    May 2008
    113
    To get the most out of waterless if I remember. each printing unit has to be at a certain temperature. You need the hollow vibrator chiller rollers with different temp control for each unit.
  6. signsupply
    signsupply New Member
    Sep 2009
    UK
  7. Mr. Litho
    Mr. Litho Member
    Sep 2009
    12
    San Diego, California
    waterless printing was a thing of the 90s
    by not using water, your color was achieved faster,and w/less amount of set up sheets
    the cost of the tank/system was enormous,and not too many pressman were able to achieve & maintain presses from scumming/plates were costly/and hard for operator to fix pin holes/scratches etc.... unless you have a pressman that understands the theory of waterless printing,i would suggest stay away,amd go w/the normal operation of offset printing.
  8. jonnyt0125
    jonnyt0125 Member
    Sep 2007
    5
    U.S.A. St. Louis, Missouri
    We printed some very nice pieces. 3oo line screen. Close to continuous tones. But as a pressman it was a nightmare. We likened it to a "bus accident"
  9. Mr. Litho
    Mr. Litho Member
    Sep 2009
    12
    what was a nightmare controlling the system.
    in the 90s i was running a 6/40 komori waterless,with tri/services system control
    alot of the pressman had a hell of a time getting used to controlling system,so it wouldnt drive up....at the time i was working for upper deck baseball cards...
    kinda tricky isnt it.
    one good thing you get a crisp color.
    and color was achieved quickly w/little set up sheets.
    were are you located who are you working for...
    is your co. still trying to work production waterless??
    im in san diego california,the job market out here now adays is terrible.
    keep in touch,if you need any help in the future,feel free to post me and i will help in any way i can. i still remember a lil about waterless , its been a while.
    good luck, take care pal
