Urgent Help with Roland 700 positioning error
1210behzad
2026
5
Iran
Hello dear experts
I have a problem with our man roland 700 machine. we changed the main convertor BKF12 and now everything is ok just our problem is that when changing the plates the system has RTR: Positioning error
We changed the parameters of Converter but nothing result
The parameters must be loaded from the original HA parameter diskette. RTR has 1480 possible errors. Which one of them.
PP. The machine does not change plates even if there is an error in the register motors.
  • You know it passes the exact position of the inductive sensor about 10 mm and then 'positioning error' appears
    Check the slow speed. If the HA parameters are wrong, it may not position properly. The HA parameters must be written to the inverter with Paraffin. The program is included in the diskette set.
    Att. PPL position:
    Check (compare) the mechanical with the electrical "0" of the machine.
    Att. PPL position:
    I don't have the machine diskete can I take a backup from previous inverter and download them to the new one?
    Yes. You can.
    Parafin is used because the file format on Roland diskettes is not compatible with the Baumuller program. Copying parameters from one inverter to another is possible with it.
    Att R704+LTL, R705+L, R706 parameter set. included parameter as TXT
    Yes. You can.
    Thanks a lot but I have a question, why each parameter has a set of 4 value ex. 10.0 10.1 10.2 and 10.3?
    There are 4 parameter packages. At startup the inverter selects the package that is set to be used. I think for you this is package 0 or 1. 3 and 4 are factory default.
    I know it has 4 data set but always it reads the one which is selected in P6 or the data sets are switching through machine running?
  • Parameter set is selected when starting the inverter. Do not play with the machine. It will become broken.
    Hello dear experts
    Hi my friend @1210behzad I have the same problem, did you solved it?
