Types of ink/best ink
Discussion in 'Heidelberg Printing Presses' started by 6colorchuck, Sep 14, 2010.
  1. 6colorchuck
    6colorchuck Member
    Feb 2009
    39
    schaumburg, Il
    Has anyone noticed that Toyo ink performs best over any other inks? We tried it and had great success. Anyone have any other suggestions before we commit?
  2. EBEN
    EBEN Member
    Sep 2010
    5
    Ndabase Printing Solutions PRETORIA SOUTH-AFRICA
    Do anyone know if the Toyo ink is available in South-Africa and what the best fountain is to use with it?
  3. Green
    Green Member
    Apr 2010
    11
    Pressroom
    Which type of Toyo ink are you referring to and what inks have you compared it too ?
  4. 6colorchuck
    6colorchuck Member
    Feb 2009
    39
    schaumburg, Il
    We are using Toyo "24/7" - we've tried handchy, and worse was "GiS". Toyo is the only ink that doesn't "pick" when backing up a job. We are using Heidelberg MO equipment
  5. The Heidelberg Guy
    The Heidelberg Guy Senior Member
    Mar 2009
    65
    USA
    To make the assumption that Toyo is the best by only comparing it with a couple inks, your only hindering yourself. I have tested over 20 different inks for a certain application, and found that although Toyo is a great ink, but didn't quite meet the particulars of our use. That being said, you may find others that work better than the Toyo for your need, just call around and get samples!
    Tim
  6. u352
    u352 New Member
    Jun 2010
    Apex,NC
    Their waterless process was one of the best I've ever used (been over a decade though). The conventional Tsp 400 series is a good HD oxidizing ink but like all of them it can lead to problems without regular washups. I used Tsp 300 a little and I think it dried even faster. Sun's Triumph series stays open better in the press but still dries like a rock. I have never tried any of Toyo's UV products.
    Somebody should put together a list of all the inks there are and their attributes. It seems like every ink company has 20+ different products.
  7. Green
    Green Member
    Apr 2010
    11
    Pressroom
    How have you come to the conclusion that that particular Toyo ink set is better then any other ink set, when you have only put it up against a few other ink sets.
    To test ink sets correctly, you should also be backing the ink up with the correct fountain solution that has been recomended to be used with the ink.
  8. 6colorchuck
    6colorchuck Member
    Feb 2009
    39
    schaumburg, Il
    Ok, well how about this - from everyones experience, what ink performs the best and doesn't pick? I work in a small shop, and we don't have time to test out a bunch of inks and fountian solutions. Any help would be appreciated. Toyo has worked the best for us so far
  9. Green
    Green Member
    Apr 2010
    11
    Pressroom
    6colorchuck,
    I'm not for one moment, saying the Toyo ink isn't a quality set.
    Every printer will have a different take on what qualities an ink set should offer and how well it should perform.
    To me a quality ink set is one that is:
    Stable when used alcohol free
    wide operating window
    Duct fresh
    zero petroleum solvents
    less than 4% voc
    high gloss / scuff resistant
    Sharp dot
    high trap levels
    Can be used on all substrates
    High mileage
    Also take into concideration, one ink set may be well suited to large perfecting presses, but not so suited to a smaller machine.
  10. Print Consultant
    Print Consultant Member
    Aug 2009
    13
    UK
    Toyo ink is also the Heidelberg Saphira ink re badged.
  11. jonprintz
    jonprintz Member
    Oct 2010
    24
    Dallas, TX
    Best is a relative term and when applied to ink the word has to be adjusted to fit what you need from an ink. Does is work well in your press w/ your fountain solution, print quality needs, not dry in the rollers but dry quickly on your stocks, etc. Only you can answer these questions for your shop......after thorough testing. If you don't take time to test you will be taking time to reprint.
    The Toyo products that we use are very good products.
  12. tim enigma
    tim enigma Senior Member
    Nov 2010
    58
    mesa
    We switched to Toyo hyplus process inks a few years ago and love it.
  13. Technical_offset.pt
    Technical_offset.pt Member
    Dec 2010
    12
    Portugal
    Hello everyone.
    I also had some problems like this.
    after several tests performed, the ink that behaved better in every type of substrate and low / high speeds was Vanson sonafresh.
    I have helped.
    ps. I do not know if your machine has cooling coils. if it keeps the theoretical value by 27.5%.
  14. spikeboy
    spikeboy Senior Member
    Sep 2014
    62
    new york
    speaking of inks iam having a drying issue when i run explorer dull stocks i am using superior elite sereies never
    had to much problems could stock be issue to acidic or bad coating no problems on coated? thanks . spikeboy
  15. FSA
    FSA Senior Member
    Jan 2011
    312
    Winnipeg, Manitoba
    i know this is an old tread but still a good topic. Toyo is ok, nothing more, not a good ink on the 8C 102, Sun chemical has had the best results for lack of picking, which is a common problem on these big monsters. Toyo works on the little DI but i prefer Heidleberg waterless ink for its stability. To each his own if you can lay down a mean solid, it dries, and goes through bindery and they don't come back at you, well then you have a winner!
    FSA
  16. aqazi81
    aqazi81 Senior Member
    Oct 2009
    827
    KARACHI PAKISTAN
    This generally does not happen. Post press is always complaining print.
  17. Robb
    Robb Member
    Dec 2014
    8
    United States-MI
    Green, that is a fine list of ink attributes, except for the 'duct fresh' idea-spikeboy is having trouble drying ink on dull stock (and I'll bet on silks and mattes and uncoateds too). Duct-fresh inks have dryer retarder (sta-open) in them, sometimes as much as 2-4%. Why would any sensible printer put dryer retarder in his ink? Even as little as .25% (one fourth of 1%) sta open more than doubles drying time on ANY stock. If your ink does not skin in the can in less than 24 hours, you are doing yourself and your company a disservice with marking, picking, gas ghosting and hours of dry time.
  18. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,092
    Vermont
    agreed that any stay open ink is going to take significantly longer to dry, and create problems in post press, and even post delivery. However..... if your laying aqueous coating as a SOP as many companies do, then there would be the added benefit of not having to clean your ink fountains every night, and less ink waste as you don't have to skin the cans before loading up fountains.
  19. Robb
    Robb Member
    Dec 2014
    8
    United States-MI
    Righto-coating and extended dryer allows for sta-opens.
  20. tzoiman
    tzoiman New Member
    Oct 2015
    Croatia
    K+e novavit supreme bio is really supreme to others in my opinion
