Troubleshooting with Heidelbergh 102 ZP
isam buk
2021
13
Jo
Good Morning Sirs,
We have a problem with our 102 ZP that is ready to start but not start, an circle around T is marked on the electronic cabinet and circle around M in CP TRONIC sreen,
Note :2 of 3 SLT supplying fuse was broken, we replaced them .
  • DYN - TEST-1
- SBM_1/2 FDFD
- MOT 7FEF
  • Machine failure icon is flashing on Electronic Cabinet as an circle around T
  • Machine failure icon is flashing on Motor as an circle around M
  • Here are attached screen capture for this issue.
Can anyone Help me please?
Hi,
This error indicates main motor brake malfunction. It means, once you presses RUN bottom, the press rotates more than 4 degrees. In most cases, the brake has a problem and you need to replace the inner brake disk.
  • Hi sir;
    Please see my instruction before:
    1) Reset the main c.breaker
    2) please be sure the FUSES, are making good contacts, and are o.k, NOT open and provide continuity.
    3) Tight very well the terminals with wire and clean very well, from corrosion, and dirty.
    4) However the indication from his error code , is that you have Voltage provided very LOW to the FIELD MOTOR.
    check very well the voltage coming from the electronic board, and see if there rectifiers bridges, power transistor, if are NOT open or leaking.
    Repair or exchange the board.
    5) Please do some maintenance for the main motor, since the motor can be NEED some clean it, Lube, and exchange ball bearings.
    Blessing
    However I forgot, you can test too the brake;
    1) lack of +48Vdc
    2) mechanical failure too.
    Blessing
    if i restart the machine no alarms >>> once i presses RUN bottom the main motor not working and the alarms Appear on CP TRONIC sreen
    ok, please review carefully the steps
    and
    *Check:
    Induced voltage stays below the setpoint value engine.
    Motor induced voltage too high for brake test.
    Blessing
    “However the indication from his error code , is that you have Voltage provided very LOW to the FIELD MOTOR.
    Repair or exchange the board “
    Is for SBM board , IGBTs ?
    Please can you tell me what is the codes mean?
    SBM_1/2 “FDFD”
    MOT “7FEF”
    thanks
    MOT TFEF*Check:
    SBM FDFD
    *Check:
    SBM1 defective .
    *Check:
    defective SBM2
    Possible IGBT defective, bridge rectifier , power transistors
    Without run I get these alarm
    SBM_1/2 0D0D
  • Hello Isam Buk, did you resolved the problem in your press?
    I have a very similar problem.
    Please tell me if you resolved it and how.
    Thanks!
