Troubleshoot
Discussion in 'Heidelberg Printing Presses' started by Ricardo, Feb 18, 2020.
  1. Ricardo
    Ricardo Member
    Nov 2017
    72
    Tucson az
    Hi, gentlemen’s. This morning I had this icon in my press. Any idea what it is? I was running 110 Lb cover (fish paper/black stock)stock at that time.I run a Heidelberg 102 1993 zp cp tronic.
  2. Jack liston
    Jack liston Senior Member
    Sep 2019
    319
    Connecticut
    It is telling you that feeder over ride motor adjusmeant is at its forward limit
  3. Jack liston
    Sep 2019
    319
    Connecticut
    It's not an issue
  4. Jack liston
    Sep 2019
    319
    Connecticut
    Clean the eyes might be dirty
  5. junker1984
    junker1984 Senior Member
    Jan 2010
    1,134
    US, Midwest
    Improper feeder set up, significant change of stock thickness, mechanical hindrance of smooth sheet travel, worn drive chain, worn forwarding wheels, bad motor/potentiometer...
    Andrei83 likes this.
  6. Ricardo
    Ricardo Member
    Nov 2017
    72
    Tucson az
    I thought so. I just tried that stock and that showed up. Could that hurt the press? Is it safe to keep running that heavy stock?
  7. Ricardo
    Ricardo Member
    Nov 2017
    72
    Tucson az
    Every time I run cover stock it’s a pain in the bud to run it. I have all kinds of problems feeding that paper.
  8. junker1984
    Jan 2010
    1,134
    US, Midwest
    How heavy are you talking? I don't recall the max stock thickness on that machine, .012" I think. If you're running max thickness, and given the age of the machine and the fact it's a perfector...your are looking at a potential calamity. That's not to say that if you use due diligence and exercise the utmost care, you'll be fine. The stock will be noisy, even on a straight printer, given the cylinder configuration.
  9. Ricardo
    Ricardo Member
    Nov 2017
    72
    Tucson az
    the sheets size is 26X40 inches. The cover stock thickness is .011. But like I said, running any cover stock it’s a pain in the bud.
  10. junker1984
    Jan 2010
    1,134
    US, Midwest
    Shouldn't be. When going from light to heavy sheet, there are adjustments that must be done for optimum sheet arrival.
  11. Ricardo
    Ricardo Member
    Nov 2017
    72
    Tucson az
    What kind of adjustments?
  12. junker1984
    Jan 2010
    1,134
    US, Midwest
    It's in your operator manual. You do have one? If you don't, and you have not had formal training, you are not utilizing your machine to it's fullest capabilities.
  13. Ricardo
    Ricardo Member
    Nov 2017
    72
    Tucson az
    Don’t have one, didn’t have the right training. Basically the training last 2 hours. Pretty much where the water are, how to make a plate/ink move. Just basics.
  14. junker1984
    Jan 2010
    1,134
    US, Midwest
    Ouch. Good luck.
  15. Jack liston
    Sep 2019
    319
    Connecticut
    When you run heavy stock you need to take some pressure off the drive wheels on feed board make sure you are not jamming sheet to head stops also side guide plate should be raised
  16. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,092
    Vermont
    There are numerous adjustments, in addition to what's been mentioned, that will help you when running cover weight stock. You really should consider some formal training for your press crew beyond the 2 hour demo you mentioned. I promise you that as long as your press crew has proven competence on other machines, and are teachable, the money will be well spent. I can also promise you that learning the finer points of any trade will not be happening, by coming to a forum and asking questions. There is no substitute for hands on training in order to get the most of your equipment. Either hire an experienced Heidelberg Pressman full time, or at the very least hire someone to come in for at least a couple of weeks to properly train your existing crew. The money will be well spent. I know of such a guy if your interested.
    junker1984 likes this.
