Triumph 5551-06 EP Programmable Hydraulic Cutter
OffsetMindset
2013
6
indianapolis
I am selling my Triumph 5551-06 EP Programmable Hydraulic Cutter includes high storage capacity programmable “EP” back gauge control module with 10 button keypad and LED display. It stores 99 programs, up to 99 steps each (up to 9 repeat cuts can be integrated into a program in a single step), digital measurement readout in cm or inches (accurate to 1/10 mm or 1/100 inch), module features memory key for repeat cuts (manual) and programmable eject function.
It has two programmable keys for quick setting of frequently used measurements, self-diagnostic system with error indication on display, hydraulic blade and adjustable hydraulic clamp drive, Solingen steel blade, solid steel blade carrier and adjustable blade guides, clamp applies even pressure along entire cutting width and is fully adjustable between 1,900 and 3,800 psi, false clamp and foot pedal for pre-clamping, electric, spindle-guided back gauge drive, electronic hand wheel with variable speed control for manual back gauge setting, bright, LED optical cutting line, mounted on casters, durable stainless steel work surface front and rear, all-metal construction, optional side tables (shown) extend working surface.
My asking price is $14999.00 If you need more information let me know! Thanks!
