Scott Franco
- 2023
- 9
- San Jose, CA
Hi,
I have read up in the forums about problems with the triumph cutter. I could use some confirmation.
I bought the cutter used, cleaned it up, replaced some parts, and now it works mostly.
Sometimes the knife stops mid-stroke. Sometimes that will be in the middle of the cutting stack. Usually the issue goes away after turning it off and on, or waiting.
The prescribed answer is to sharpen the blade. I don't believe that is the issue because I remove the stack of paper and it still stops at the same place, IE, it is cutting air and still stops. I also checked if the clamp is rubbing, but taking off the top cover, I can see daylight between the clamp and blade.
One of the posts here said the limit switch may have gone bad. All advice appreciated.
Scott Franco
San Jose, CA
Scott Franco
San Jose, CA
