The Procedure to calibrate the TAM card on Polar SDP 115
egyeng
2011
Egypt
anybody can help me about the right procedure to adjust the TAM card on Polar SDP 115 cutter. to get the accurate measurement of the backgauge because there is different about 2 mm
Hi egyeng, how are you? do you get your answer?
I also facing such problem on my 115.
Have you an ERROR Code Number List of 115?
DigPrint
  • Hi egyeng and DigPrint,
    What error code number you are looking for?DigPrint.I can post here,but I can't post all of them.
    please read this:-
    Adjustment of reference point
    Before any adjustment to the reference point is started,
    make shure that over - undercut as well as parallel cut
    is properly adjusted.
    A coordination between the actual measurement of knife
    cutting edge (=cutting line) to the rake front and the digital
    measurement display will be established with the adjustment
    of the reference point.
    For a rough alignment of the reference point it will be
    necassary to set a measurement data into the align switches
    (codier switch) on the left side of card TAM.
    On the Model 155 EMC it is approx. 77.5 cm
    On the Model 115 EMC it is approx. 57.5 cm
    In case that this measurement data had been set already
    and should be checked or corrected,then the rough alignment
    need not be repeated.
    Move backgauge to 10cm by fineadjustment handwheel and make the first cut.
    Turn the small paper ream by 180 degree and align careful
    against the backgauge rake. Make a second cut and take
    measurement with a pocket caliper.
    The result in this example is a measurement of 8.385 cm
    which is in this case shorter as shown in the display by
    the backgauge position. As the next step. the difference
    has to be established.
    10,000 cm
    - 8.385 cm
    1.615 cm
    This dimension of 1.615 cm will now have to be subtracted
    fromthesattingonthealign switches. Since the small paper
    ream is actual smaller as the shown display. If the small
    paper ream whould have bean larger, then the difference
    should have been added.
    77,500 (value setting)
    - 1,615
    75,665 (new value to be sat at the codiar switches)
    _7__5___6_____6_______5____(TAM codiar switches setting)
    dm cm mm 1/10mm 1/l00mm
    After the correction has been done, move the backgauge
    passing the machine table center in order for the correction
    to become effective. A readout of this new point to take
    place for the incorporation of the new reference point. It
    is adviseable to test cut this position by 3 equal sizes as
    described in the service manual.
    The backgauge has to be operatad in standard mode when
    the reference point correction is being worked on.
    If your Polar Linear Measuring System defective you can try our (LMS mod. set) cost you only quarter of Polar price but with high accuracy and reliability for details please visit http://welvin.fabhosting.co.cc/lms/
    Please visit my site for any Polar spare parts or enquiries http://www.welvin.com or http://welvin.no-ip.org
    mail to: welvin@welvin.com or simon@welvin.com
    Welvin Engineering Limited
    Simon Yeung
    Hi Simon,
    Thanks for the reply,
    What I'm looking for is all The ERROR Code list for Polar 115 EM
    Thanks for your help
    Best Regards
    DigPrint
