The main motor pcb inverter card for the headle berg sm 66
Discussion in 'Heidelberg Printing Presses' started by JosepWibi, Aug 21, 2023.
  1. JosepWibi
    JosepWibi Member
    Mar 2023
    17
    Indonesian
    The main motor pcb inverter card for the headle berg sm 66 machine has a key mark. What indication? Because the motor can not be started.
  2. Beguin
    Beguin Senior Member
    Jan 2020
    395
    Côté d'ivoire
    hello dear sir, what is the problem with your machine?
  3. JosepWibi
    JosepWibi Member
    Mar 2023
    17
    Indonesian
    thank you for the response.
    Problem: the main motor is started, it can only run one round. then stop alone. Can't start again. After being reset by turning off the electricity, it can be started again. But yeah, it's still the same. One lap self stop.
    Thank you
  4. Adil
    Adil Senior Member
    Nov 2021
    1,376
    Casablanca
    Hello sir give me dyn test and init test to see what happends
  5. Beguin
    Jan 2020
    395
    Côté d'ivoire
    can you show us the init test and dyn test! Thank
  6. JosepWibi
    JosepWibi Member
    Mar 2023
    17
    Indonesian
    thankyou for the response
    this is a picture dyn test and init test
  7. JosepWibi
    JosepWibi Member
    Mar 2023
    17
    Indonesian
  8. CHOCK
    3,092
    MSK is sending signal failure , by that reason STOP press with the message.
    Test and clean very well, the EDGE connectors of PCB from the cptronic, modular or compact or cpc ,and machine.
