Tecnau Roll to Cut System
ExoticDPS
With
Tecnau LX550 Unwinder
Tecnau TC1550 FL1 Wide S Dynamic Processor
Tecnau 530 Buffer System
Tecnau 566 Stacker
2014 Manufactured, 2015 First Installed
Always Under Tecnau Direct Support
Fully Refurbished, Performs Like New
Complete Unit
Speed Max.: 106 m/min (350 ft/min) to 137 m/min (450 ft/min)
Feeding: Pinfed or Pinless
Paper Weight: 40 – 200 gsm
Web width: 140 – 520 mm (5.5" – 20.5")
Form Length: 90 – 495 mm (3.5" – 19.5") or up to 710 mm (28")
Stack height: 250 mm (10") 2000 sheets
Offset: 15 mm (0.6")
Output Options: 1-up, 2-up, 3-up with offset and slit merge
Dynamic devices: 2, 4 or 6 cross half web cylinders for 2-up applications for perforation/scoring
2, 4 or 6 independent vertical knives for perforation/creasing
Blades x cyl.: 1 blade per cylinder as a standard
Punch hole pattern: Dynamic 2-, 3-, 4-holes or tractor hole punching or round corner & 45° die cut
Punch Hole Diameter: 3 – 8 mm (0.1” – 0.3”)
Maximum Speed:
Punching: up to 160 m/min (up to 525 ft/min) (Punching over 425 fpm requires application review.),
Tractor Punching: up to 180 m/min (up to 590 ft/min)
Perforating: up to 244 m/min (up to 800 ft/min)
Paper Weight: 40 – 250 gsm
Web width: 102 – 560 mm (4” – 22”)
(Process width: 102 – 521 mm & 560mm up to 584 mm (23")
Form Length: 102 – 812 mm & up to 2235 mm (4” – 32” & up to 88”)
Interested? E-mail us to contact@exoticdps.com for more details
