Technotrans Tripping
Discussion in 'Heidelberg Printing Presses' started by Eric amper, Sep 9, 2019.
  1. Eric amper
    Eric amper Member
    Apr 2019
    10
    Phillipines
    Good day everyone!!! Im running a sm-74 6 color machine and we are using technotrans north america version im having troubles about tripping issues (electrical) it use to had an interval at about 8 hrs then starts trippin again problem solves after restarting it and and turning on the OL breaker... im running with T-temp turned off and im only using the dampening temp.. probably some of these pictures will help.. thanks everyone...
  2. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,051
    Vermont
    If you're using a North American version of the Technotrans have you taken measures to insure correct voltage? Also may want to make sure your not building up to much heat as a result of dirty cooling unit. Is there a big buildup of powder inside the guts of the unit?
  3. CHOCK
    2,871
    Please see your
    1)schematic diagram, according with schematic the Technotran is consuming 40Amp, you must use
    some Amperimeter and test how much current is there??
    2) See with a DMM, if the Input Voltage is according with the Technotran version US 460Vac, 3 phases, 60HZ, if the Input is higher adjust the Tap Primaria in your transformer, and vice-versa if lower.
    3) After you make the correction, measure again if the CB 01, is tripped? if does you have possible problems : a) Transformer XFMR01 : Winding Overheating , or defective b) Rectifier defective or after Rectifier some load that they feed( see the schematic electric) in Short, or Overheating.
    4) Try to give Better ventilation to control Box, maybe installing additional Fans for better ventilation.
