TEC Lighting TRUVIL-16D
terrymcv
2009
222
Florida USA
16" Hand-Fed UV Coater, 1PH, 60Hz
The TruCoat UV Coater is truly a unique coating technology. Its sophisticated design can increase your profit margin by enhancing the aesthetic quality of your products and diversify product offerings. It was designed from the ground up to offer the very best in performance and simplicity. TruCoat technology can provide your business the highest possible UV coating available, and is simple enough for anyone to operate.
Some features include an “Easy to Use” touch screen, variable intensity IR lamps and quick-change rollers that take only 5 minutes to replace. The TruCoat system is the ultimate coating solution to help you become a threat in your business.
FEATURES
• Apply gloss-satin and matte coatings
• Coat toner based, offset or inkjet with ease
• Quick change textured rollers for an array of finishes
• Speeds of up o 4,000SPH
• High production auto-feeders and stackers available
• From start to coating in less than 5 Minutes
• Less than 10 minutes to switch between different coatings
• 0 VOC UV coating and wash-up fluid
• UV coated documents are 100% recyclable
• LESS THAN ½ PENNY PER SQFT
• Modern/compact design
• All steel construction
• 3 roll application system with quick-change roller design
• Stainless steel doctor blade
SPECIFICATIONS
Model: TRUVIL16D
Size: 16” (40cm) wide
Max Sheet: 16” (40cm) x Infinity
Sheet Thickness: 150-600 GSM
Sheets Per Hour: Up to 4,800
Power: 220V, 1Ph, 60Hz, 35A
Click Link to View Manufacturer’s Information
It's an inline coater which means you can put it at the end of a digital machine and it will go right from the delivery of the machine to the conveyor of coater.
Purchased 09/2013 ( sold new $19.000 Have invoice if needed )
Located MO.
Have photos.
Shipping available
$5,800
Terry McVittie
Email: terrymcv@gmail.com
Web site: http://www.equipment-exchange.net
813-391-3436
Terry still available?
Luk
