t in circle SpeedMaster-74-2P
Andy muller10
2023
45
Around the World
Hello everyone.
here is a serious problem a T in circle and dyn err message photo has been attached. need your help please
Loop test of ewk x11,x12,x13,x14 nd evm 1 x1 ,x2 and evm2 x3 and x4.
As conqéquence the servo drives can not be conteolled and auxiliary too
Check connexions remove the plug of ewk x11....14 clean , spray and put it again
Also evm x1 ...... x4
Good luck
  • Loop test of ewk x11,x12,x13,x14 nd evm 1 x1 ,x2 and evm2 x3 and x4.
    Good luck
    Hello Dear Friend,
    thank you very much in advance for your quick reply and help. And very happy to read your supportive guidelines. Before getting your message i was browsing and explore between all the pages (here in database of forum) and a 1km long list of the reasons of T error have been read. Forsure will back here with answer because it is an important repetitive error.
    Thank you
    Andy
    Hello Dear Adil
    I hope it finds you very well gentleman and thank you again for your efforts and supports. I have done what you have said but didn't help. I forgot to say that this press has an isolator step-down transformator ( for the main electric power i mean, located out of main cabinet, by customer) and by chance i checked the output voltage on it and at one single phase the the value was over 30 volts more than it should be. i have swapped this transformator with another correct (same power) and "T" disappeared. it sounds very weird to me, but it seems fault has been fixed (hopefully) and now it is printing...Any way hereby I would like to express my special gratitude for your help and Best Regards, Andy
