Suction Head height not working
Hello guys -- can anyone help me Roland 700 feeder head problems
Error:- suction Head height
Please give me solution information
Error attached photo
Please proceed according; any doubt send me his email, I can not supply the mine, to due Rules of Forum
Basic adjustment of the MABEG feeder to the press
• Switch on feeder coupling (+BA3A, feeder ON)
• Turn machine forward until you can clearly hear it click in and the suction tapes are running.
• Jog machine forward (if jogged back the coupling disengages) exactly to 180 degrees (multi-functional display +BA3A)
• Set feeder timing adjustment to middle position (to S709 manual adjustment: using hand crank to middle of the scale; from S710 electrical adjustment: from Leitstand
PR-PRESETTING-FEEDER/DELIVERY – FEEDER TIME ZERO)
• The red marks on the bearing block feeder frame A-side inside must be flush (3);
• also the red marks on the hexagon of the suction head (B-side) must be flush (5)
  • I open the motor cover and check inside is card fult.i have new motor but I don't know how to set Servo motor address so please explain me please.
    This is my personal email shreesaini18@gmail.com
    Thank you for advance
    To reset from the console: + in the auto zero menu. Then with the up button on the feeder.
    EA2 motors are left and right. They also differ in gear ratio. They are addressed with the EA2 program or with the hand terminal in addressing mode.
    PP. Your hand terminal is in passive mode. Activate first.
    Dear Sharwan,
    It is better you call technician to fix motor program
    You can contact me at
    Sandeep Kumar
    +919810902830
