Onesiforus Yabes Ronanus
- 2025
- 7
- Selangor, Malaysia
Hi all and Happy New Year 2026.
I am new here and would like to discuss on my study analysis on dampening solution impacts towards waste paper quantity.
Currently I have been experimenting and collecting data from Nov 16th 2025 till Dec 20th 2025 to find the best parameter range for conductivity, pH and temperature.
Constant Variables are:
1) Dampening are formulated new every week using our own standard.
Result from my analysis,
1) pH does not fluctuates aggresively with coefficient of variances (%) of 6.55%.
2) Temperature does fluctuates moderately with coeffiecient of variance (%) of 17%.
3) Conductivity does fluctuates aggresively with coefficient of variance (%) of 26.4%.
Hence, from this analysis I correlate with the amount of paper wastage with conductivity value when machine is running within the
As for conclusion, this study suggest to as conductivity increase more than 2.0 mS/cm, defect rate increases due to color variation, smearing and hickeys.
However, since I only collected data for 1 month, I am more likely to question the accuracy of this study whether it is reliable or not. Hence, I would like to discuss this matter further on the dampening solution parameter range based on other printer experiences.
Your reply will be much appreciated. Thanks!
