Static buildup on sheets coming out of the sheeter so bad it won't go into the stacker. Running 17# self contained paper for the duplicate part of checks. Running on didde dg-860 with no problems, also running on a dg-860 rebuilt by super web with major static issues. Static eliminate bar is working, running tinsil and dryer sheets everywhere. The 2 presses are right next to each other so climate control shouldn't be the issue. Is it possible that the press isn't properly grounded?
Hi : Please test the high Voltage from the static bar, see your schematic diagrams, Normally is over 1.000 Vca take care using the DMM, and high transformer possible faulty. 2) Use some electrician for to review the bar for Ground Control Panel in the building, can be corroded for the time, possible change Blessing
