SM52
- 2012
- 7
- Utah
We are having a startup problem on our SM 52 2 color, year on machine 2000.
It will not boot up past the Heidelberg logo. My research on this forum, it seems there is 2 possible ways to reset it. One is to reset the cpu by grounding out a certain pin while the machine is under power and the other option is to put a jumper on the X-11 plug. My question is what pins do I put the jumper on on the X-ll plug and do I ground them out on the machine? Or do I jumper them from pin to pin? Should the machine be under power when jumping the pins?
Attached are photos. I put numbers on the X-11 plug photo pins as reference to indicate to me which pins need to be jumpered to each other or to the ground.
Any help is appreciated.
