Start-up problem on Wohlenberg MCS 2 TV
Discussion in 'Cutters and Trimmers' started by Hamed Ndiaye, Sep 19, 2022.
  1. Hamed Ndiaye
    Hamed Ndiaye Member
    Sep 2022
    5
    Dakar Sénégal
    Good evening everyone, I'm new to this forum. My problem is that when I start the cutter, nothing works, neither the screen lights up, nor the K0 and K22 contactors activate, apart from a light. With a button lit on the front panel, all fuses are OK.. Need help please...
  2. CHOCK
    2,797
    Hi sir;
    Please review the Circuit breaker F33 and reset it, AFTER Q1 main switch( test main switch, for loose wires, or dirty contacts, or worn or defective)!!!
    Let me know.sincerely
  3. Hamed Ndiaye
    Hamed Ndiaye Member
    Sep 2022
    5
    Dakar Sénégal
    Hello, thank you for your advice, all of this is correct, the problem is that the K22 does not activate as soon as Q1 closes, and this is possible if the K216 relay is OK, but this one comes from UCP... In addition my screen does not even turn on, thank you for your cooperation
  4. Hamed Ndiaye
    Hamed Ndiaye Member
    Sep 2022
    5
    Dakar Sénégal
    Lorsque je démarre, il y a seulement ce voyant qui s'allume sur le tableau de commande et 05 autres petits voyants sur la carte CPU. J'ai vérifié au la tension ĎC de la carte, j'ai 12.6V et 5.2V bien présent. Voir ci-joint les photos, merci de votre aide 20220924_223202.jpg 20220924_181925.jpg
  5. CHOCK
    2,797
    Hi sir;
    I really do NOT understand very well, what is the situation of his machine, first you say; ¨thank you for your advice, all of this is correct¨
    You must test very well;
    1) the Power Supply, Input of Vac in tolerance around 10% up or down.
    2) the Non regulated Power Vdc, in tolerance around 10% up or down.
    3) The Regulated Power Vdc, in tolerance aroun 0.7% !!!!! Very critical up or down... like + 5vdc
    4) you are indicating that in the Display , you have a small light, but do NOT see it, if the CRT is ON, if that situation is there NO display in CRT, please you problem, with the issue in the 3 stesps mentioned before, Of course,, must test too , the +15Vdc, +5.2Vdc?? Not good and +12.6Faulty.. and possible flyback of CRT.
    Let me know, follow his schematic diagrams electrical.
  6. Hamed Ndiaye
    Hamed Ndiaye Member
    Sep 2022
    5
    Dakar Sénégal
    ok I understand, I'll get back to you as soon as I have checked all the points you have indicated.. thank you
  7. Hamed Ndiaye
    Hamed Ndiaye Member
    Sep 2022
    5
    Dakar Sénégal
    Hello I apologize for the delay in answering you, I was very busy on another machine, I followed your advice, I checked and rectified the AC and DC voltages which were out of tolerance and also cleaned the motherboard and the keyboard card and I managed to start the machine on the first try and when I stopped and wanted to restart and it refused.. even after several tries, nothing at all. I checked the DC voltages of 12Vdc and 5.2Vdc, it's correct, so I don't understand this phenomenon, sometimes it works and then it refuses, you asked me to check the +15Vdc voltage, but I don't not know where is this voltage? please tell me and help me solve this
  8. CHOCK
    2,797
    Hi, +5.2Vdc, is Not good!!!.
    you must tracker+15 VDC, the schematic wiring diagram,
    Clean, all the edge connectors!!!, Must of the 70% of failure in electronic is to due this.
    If the problem persist?, Please Reheating all electronic board and back plane, x dry+ colder solder joint, very well.
    Blessings
